Automated 'overnight' benchmark suite
4 May 2011
Fairly straightforward question - are then any suites of benchmark tools out there? I would like to be able to set off a benchmark run, and have it run loads of tests, one after the other.
I think the best example of what I want to do is Toms Hardware - when they bench systems, they run a variety of apps, at a variety of resolutions and quality settings.
Is there anything out there that does this, or do I need to create my own?
Thanks, that does indeed look quite useful - will put it on my shortlist :)
I swear I remember an application I useds years ago that would benchmark based on games you owed - if memory serves, you could select a bunch of your games (Based on what you had installed and what the tool could use), resolutions and quality settings, and it would run through all the games at all the settings automatically, playing a demo and getting min, max and average benchmark rates. Anyone else remember this? Is it still around?
