I've recently had the shift solenoid C changed on my IS250 as it was exhibiting 2 main issues...
1. The car won't shift past 3rd or 4th. Sometimes it's 3rd and other days it will be 4th.
2. If I let go of the accelerator say at 70mph the revs will drop rapidly to just above 1200 ish and by that time the car would be at say 60mph. To accelerate I have wait for the revs to rise again for a few thousand revs before the car accelerates. I have to do this gently otherwise the car jolts forward as the engine speed isn't matching the gearbox.
So I came out of the dealership £500 down about a week ago thinking the shift solenoid change that originally brought up a p0761 iirc had fixed the issue. So 10 mins into my journey home I saw the engine light, VSC and traction light has come on again and I was stuck in 3rd gear again.
Turned around and went back to the dealership and they've agreed to refund me the £500. We've agreed that I will be provided a courtesy car from this Saturday to Wed and they will see what they can do. They will put the old solenoid back in, refund me £500 and during those 5 days hopefully resolve the problem including changing the transmission fluid.
Before then though I've noticed the two faults above have been intermittent as I've managed 3 days without any faults though the revs do appear a tad lower than normal as when I let go of the accelerator I still see rev drop though not as severe. About a few hundred rpms. Reading Lexus forums, there have been mentions that drivers have resolved their VSC, engine and traction lights by reconnecting the vacuum line on the intake as it can come loose, changing oxygen sensors and making sure the fuel cap is tight. The latter is how I managed to resolve the problem for 3 days. The oxygen sensors I'm not capable of doing of course and everything seems ok intake/vacuum line wise.
So after 3 days I've got the 2 problems again so this Saturday will be sending the car in. Worse case I've been told 2nd hand replacement transmission will be 2200+labour+vat as Lexus will not take the existing one apart. Reading online I just don't think it's the gearbox.
Quite gutting this. 7 years old and about 105000 miles. It's probably worth 5K if it was faultless and it be madness to change the gearbox!
Any advice appreciated on how I should handle this with the dealership or independently?
Many thanks
