Hi everyone, I’m wondering if I can pick people’s brains, any help/advice would be much appreciated.
So my PC has been on 24/7 for the last few weeks. I shut it down today for the first time in quite some time to sort out some cable management. Now when I try to power it back on it shuts down at various times (Ranging from immediately, to a couple of minutes). I’ve took all the side panels and everything seems to be spinning and powered up. It’s a SFF build and no cables have been moved etc (everything was cable tied in place during build).
PC Spec: CM NR200 Case, 5900X, 32GB RAM, RX 6800, GB Aorus PRO AX motherboard, Corsair SF750 PSU, NZXT X63 AIO.
A question to the experienced amongst you, would I be right thinking due to the random times of the shutdowns. It’s MORE likely to be CPU temperature related than PSU power related?
So far it has shut down whilst trying to load into windows and also whilst sitting in BIOS, whilst in BIOS all SDDs and RAM was recognised.
Whilst in BIOS I noticed that only SYS1 and SYS2 fan were spinning with readings, whilst CPU fan (was not spinning and NO reading) although the 2 fans on my AIO were spinning. This is leading me to think that it may be the AIO that is at fault.
I appreciate it could be one of numerous things causing the problem. But any advice or opinions would be helpful and much appreciated.
thank you
thank you
