Automator help
7 Nov 2002
Normally in Bed Sleeping
I'm trying to use automator to perform a simple task but having never used it before I've come here for some help. The task I want to perform is to propagate folder permissions downward on a particular directory every night.
My guess is I need to create a service for files or folders in Finder then Get finder items > Run a shell script
Does this sound right or is there a better way? I also don't know the shell command script I would need to add in the Run Shell Script section.
Thanks
possibly for a more knowledgable audience try the MacRumors forum
http://forums.macrumors.com
PG
Thanks for the recommendation I've post a question on their forums. I've got a little further so i'll leave the same question here as well just incase some here knows the answer.
I've created an automator workflow to propagate permissions on a directory however i'm having some trouble over writing existing permissions.
This is the script;
Code:
chmod -R +a "<jsmith> allow read,write,delete" "/Users/xxxx/Documents/Permissions Test"
If I check the permissions in finder before I run the above script I see the following;
Name Privilege
<jsmith> Read
Once i've run the script I see;
Name Privilege
<jsmith> Custom
<jsmith> Read
I don't want to add another entry I just want to update the permissions to Read & Write
Any help would be appreciated.
