Autorebooting String for Routers
Caporegime
25 Jul 2003
FR+UK
Just wondering if anyone has knowledge of this or if anyone knows their way around a netgear a bit more than I do...
Currently, I can pass these strings to a variety of Netgear model routers, and they will automatically reset the router:
PHP:
POST /cgi-bin/webcm
getpage=..%2Fhtml%2Fframe.htm&errorpage=..%2Fhtml%2Findex.html&login%3Acommand%2Fusername=xxxx&login%3Acommand%2Fpassword=xxxxx&var%3Aerrormsg=Error
POST cgi-bin/webcm
getpage=..%2Fhtml%2Ftools%2Frestartmodem.htm&logic%3Acommand%2Freboot=&var%3Arestart=0
POST /setup.cgi
todo=reboot&this_file=diag.htm&next_file=diag.htm
BASIC admin:admin
GET /nocache.cgi?next_file=reboot_pg.htm
BASIC admin:admin
POST /xslt
PAGE=A02_POST&THISPAGE=A07&NEXTPAGE=A08&CMSKICK=&NEXTPAGE=A08&THISPAGE=A07&PAGE=A08&PASSWORD=xxxxx
POST /xslt
PAGE=A08_POST&THISPAGE=A08&NEXTPAGE=A08_POST
Recently however, with newer models and in particular the FVS318G, this doesn't work. Trying to crack it but not having much luck..any ideas?
The script is simply accessing the web interface of the router and performing actions.
Have you verified that the relevant web interface pages have not been changed, renamed or moved?
It has a telnet interface, so might be possible to work out a method via that.
The router has a diagnostics.htm on which the reboot button appears to access platform.cgi.
