autorun.inf help needed
19 Oct 2002
Bath
Hi guys am trying to make my mobile phone's memory stick autostart a program when its detected using a Autorun.inf script.
Currently it looks like this
Code:
[AutoRun]
Icon=pod.ico ,0
Open=setup.cmd
The setup.CMD looks like this
Code:
@echo off
"c:\program files\MyPhoneExplorer\myphoneexplorer.exe"
exit
But it will not work! The Icon will show but it will not start the batchfile to run the program.
Any ideas?
Why do you need a script to run one executable? why can't you call the executable straight from the autostart file?
I tried just running the exe called direct from the autorun.inf but it did not function as it is on my hard drive, i thought that originaly this was the problem so tried the setup.cmd script.
What happens if you just double click setup.cmd?
program loads with no problem
shouldnt it be setup.bat ?
better off being a cmd rather than bat they are essentialy the same thing the bat being the older format DOS batch file and the CMD being a Command script file.
I think i have worked out the problem!
I had installed VMware workstation and that disables autorun to stop it interfearing with the host and guest operating systems, i have since uninstalled VMware but it has not re-enabled autorun.
Have tried using tweakUI to turn it back on but that does not work. Any ideas?
Fixed it!! i was right and VMware was the problem
and here is the fix
Open up Regedit and goto
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer
and delete
NoDriveTypeAutoRun
Restart explorer (log off and on) and jobs done :)
