autorun problems
27 Oct 2005
Netherlands
Hello,
Since i installed (and uninstalled) alcohol 120%, each time i boot all of the cd's i have in my dvd drives and all 4 emulated discs i have in deamontools each time i boot autorun, how can i disable this??
Im tired of shutting down 6 autoruns each time i boot and i h8 the added boot time, i dont want to disable autorun for when i put in a new cd or something, i just dont want it to happen when booting.
Hope anyone knows how to fix this.
Might seem silly, but have you turned autorun off on the cd drives?
And also disabled autorun in the virtual drive aps?...
EDIT: Just noticed you want autorun but not on boot, can't say i've heard of your particular problem, what answers did google turn up?....
Sounds like a windows autorun issue rather then the software since its happening across all drives.
yeah i just want it gone when booting, and yes it happens on all drives, real and virtual, i cant find anything on google: they are related autorun to stuff that starts with windows wich i can also edit with msconfig, and in msconfig i cant find anything not correct :(
