autostart.ini
19 Jul 2006
Hi,
I'm struggling with this,
got a folder with some html pages in , the main been start.htm
i have created a autorun.ini file with the following in
Code:
[autorun]
open=start
also tried
Code:
[autorun]
open=start.html
and
Code:
[autorun]
open=shellrun.exe start.html
both ini file and start.html are in the root of the burned cd.
put into cd drive, and it don't work, just the windows what do you want to do with the cd window pops up.
What am i doing wrong? do i need a autorun.bat as well? and what would go in them both?
:S
TIA
Thanks, needed an autorun.bat in there as well. This over rides the what do you want to do box.
The point is getting the audience to the correct page.
