25 May 2007 at 18:02 #1 A[L]C A[L]C Soldato Joined 18 Oct 2002 Posts 7,514 Location Maidenhead Does anyone have a replacement for Autounpack which works in vista?
26 May 2007 at 16:06 #2 A[L]C A[L]C Soldato OP Joined 18 Oct 2002 Posts 7,514 Location Maidenhead Anyone? Need something which can repair .rar files with their .par's
26 May 2007 at 16:11 #3 NathanE NathanE Soldato Joined 21 Oct 2002 Posts 18,022 Location London & Singapore QuickPAR?
26 May 2007 at 16:26 #4 A[L]C A[L]C Soldato OP Joined 18 Oct 2002 Posts 7,514 Location Maidenhead NathanE said: QuickPAR? Click to expand... never understood how to work that program
26 May 2007 at 19:16 #5 tomos tomos Associate Joined 17 Jan 2004 Posts 2,304 Location Liverpool what's to understand? install it, run your par2 file and associate it with quickpar. it does the rest for you iirc
27 May 2007 at 16:42 #6 csmager csmager Soldato Joined 30 Dec 2003 Posts 5,770 Location London I'd highly recommend the latest Beta versions of Newsleecher. They'll queue up all the files and queue up (but pause) all the par files. It'll then monitor the files, download the par files it needs, repair and then extract for you.
27 May 2007 at 19:18 #7 fornowagain fornowagain Soldato Joined 3 Nov 2004 Posts 9,873 Location UK A[L]C said: Does anyone have a replacement for Autounpack which works in vista? Click to expand... Like this?
27 May 2007 at 19:21 #8 killer_uk killer_uk Soldato Joined 12 Mar 2003 Posts 4,068 Location OcUK HQ fornowagain said: snip Click to expand... Mine works fine as well
27 May 2007 at 23:09 #9 A[L]C A[L]C Soldato OP Joined 18 Oct 2002 Posts 7,514 Location Maidenhead mine didnt... will have to try reinstalling it!
28 May 2007 at 10:44 #10 bledd bledd Don Joined 21 Oct 2002 Posts 46,868 Location Parts Unknown fornowagain when doing screenshots, hold left alt when pressing print screen (it only copies the current program in focus), or use vista snippet tool!
28 May 2007 at 11:52 #11 A[L]C A[L]C Soldato OP Joined 18 Oct 2002 Posts 7,514 Location Maidenhead bledd. said: fornowagain when doing screenshots, hold left alt when pressing print screen (it only copies the current program in focus), or use vista snippet tool! Click to expand... vista snippet?
28 May 2007 at 12:00 #12 bledd bledd Don Joined 21 Oct 2002 Posts 46,868 Location Parts Unknown ah, snipping tool http://windowshelp.microsoft.com/Windows/en-US/Help/1337cdba-52a2-4704-ad4d-2d7bace605b41033.mspx
