If your new Focus needs it doing and it's the Zetec-SE engine (1.4 or 1.6) then it's an easy job and you can do it yourself for less than £20...
You're a liar.
Excuse me but I am notBelt was £16, jack up front end, remove drivers side wheel, remove shield, release tensioner with ring spanner, pull old belt off and route new belt. Simples. If I can do it, anyone can. Granted it was on my Fiesta but it's the same engine and on inspection of my Dad's Focus it looks as easy.
...just remember to take the ring spanner off before starting the engine![]()
i have been on the eurocar parts website and I can only find the timing and drive belt?
The drive belt is £8.86 and the timing belt kit is £34.44
It's the drive belt you need. You will often find it referred to as the drive belt, the auxiliary belt, fan belt or in some American literature, the serpentine belt. They are all essentially the same thing, a belt which drives all the ancillary components such as water pump, air conditioning and alternator.
The timing belt (or, cambelt) is different. It drives the engine cams, and is much more complicated to replace.
To add, is this the same as the 'alternator' belt or is that something else as well?
