Hey folks,
Just got myself a new tv cabinet and trying to work out the best way to fit all my kit into it.
I've found out that both the amp and centre speaker fit nicely into the centre of the unit, however it leaves very little space around the amp. I'm guessing this is asking for trouble as it will over heat? Picture below of how it looks.
Not the best picture sorry. Hope you can see the issue though. Its not the end of the world as I could move the shelf up and put the sky box where the speaker is to have an inch or two of ventilation. The Onkyo manual says that it needs 8 inches about! Is that overkill? I'm going to drill into the back of the cabinet and put lots of extra holes so aid ventilation, both for the centre area and the side cupboards which will have a HTPC, Xbox1 etc.
Any advice welcome!
Any advice welcome!
