AV Forums not displaying properly
29 Jul 2004
Esher
Recently AV Forums stopped displaying correctly on Chrome on my laptop.
I tried deleting the cookies for it and also Ctrl F5 but nothing has solved it
Anyway to fix this or are people having trouble as well?
Also it works on IE perfectly :confused:
Thanks!
Make sure you haven't managed to get Chrome to block content from avforums - it looks like the CSS isn't being downloaded. If you have adblock check that too.
I don't use chrome, so I don't really know how it works.
You have any plugins installed?
You tried it in any other browsers?
It was working fine a few weeks ago, I have Ad Block blocked but allow AV Forums.
I do have a few other plug ins but as I said never had an issue before. I will disable all of them and try again.
Yep, works in IE perfectly
Ah turns out it was an extension. Thanks for the help!
Ad Block Plus was the culprit, not sure as of why it's started happening... oh well working now!
