Hi all, go easy i've not posted in years
I have recently got an Apple TV but am having a problem with Dolby Vision, I can run the menus and any content at 4K HDR 60hz without issue, literally no problems at all, Gemini Man for example.
As soon as I switch on Dolby Vision from the settings menu at 25hz, 30hz, 50hz or 60hz my screen goes all purple and pink, however if I set this to 24p (23.etc) then Dolby Vision works. I have backed this up by going onto Netflix and loading up The Crown with his 25 content, the TV goes pink and purple, watch Stranger Things however and this runs fine, because this is 24p.
I have an LG B8 OLED from a few years ago and the inbuilt Netflix app plays any Dolby Vision content at any refresh rate, so the issue is somewhere else.
Plugging the Apple TV directly into the TV Dolby Vision works at all rates without issue, I have tried multiple cables and essentially isolated the issue to the AV receiver, when ever this is in the loop the issue is there. Simple answer buy another one but I need to understand why an AV Receiver that can do 4K 60 HDR10 can't do 4K 60 Dolby Vision, well in fact it can ONLY do 24p Dolby Vision, it won't even do 25 without the screen going purple.
Its not the most amazing amp in the world and to be honest probably pre dates DV, but it claims to simply passthrough content so where is the bottle neck?
It is a Pioneer VSX-531 which is spec'd as having 'UltraHD Pass-through with HDCP 2.2 (4K/60p/4:4:4) HDR Support.
Sure I can just get a new amp but I would like to understand why this isn't working?
Any help would be great.
