- 18 Oct 2002
- Nottingham
Bit of an odd question but is it possible, with AV recievers which can upconvert a component signal to HDMI, to pass a VGA signal through them to the HDMI port by using on of the normal VGA to component adaptors (i.e. on of the £2 ones).
Reason for askings this is that im prety sure jsut because these adaptors change the connections, they don't change the singal as such to a component signal (I have a sharp LC-42xD1E, which only has a VGA port, and you attch component via a converter to the VGA port and then have to slecet between the signal type in the menu).
