AV Switch wiring help please!!
25 Jun 2011
Aberdeen
Afternoon everyone,
I've just had a massive brain trump and I can't remember how I wire up my Dimastech anti-vandal switches.
I can't see any documentation to suggest whats what.
Have 5 pins on the actual switch, 1 x 12v, 2 x 'ON', 1 x square/round edge box and one un-marked.
And on the cables I have 2 x Yellow (?) 1 x red (12v?) & 1 x black (gnd?), both yellows terminate to the same block (2pin) and the red and black each terminate to their own single pin block for the FP headers.
Anyone?
Been googling my little socks off and finding very little information.
Basically I've narrowed the two yellow (12v +/-) as being for the LED, black for common and from what I can make out in both a power and reset switch they are always connected as 'Normally Open'.
Can anyone confirm/deny/hint :confused:
Edit: Now reading that red (+5v) = +, Black = - (for LED) and that then leaves the two yellows.
Did you sort this?
If so care to share?
If not maybe this will help
I think it should be, NO and Com to the motherboard headers for powering system ON, and the led for the power switch from the motherboard header is the ones marked +/-
