KFA2 GeForce GTX 1080 HOF 8192MB GDDR5X PCI-Express Graphics Card @ £619.99 inc VAT https://www.overclockers.co.uk/kfa2...dr5x-pci-express-graphics-card-gx-089-kf.html
NVIDIA’s flagship GeForce® GTX 1080 is the most advanced gaming GPU ever created, powered by the high-performance, energy-efficient new NVIDIA Pascal™ architecture. Pascal enables truly game-changing performance with captivating sights and sounds, as well as next-generation VR performance that offers the lowest latency and plug-and-play compatibility with leading headsets.
NVIDIA Ansel Technology exclusive to 10 series allows you to grab a screenshot in supporting games such as The Divsion and upcoming Unreal Tournament from any 360 degree position, ability to increase resolution, use cool filters so that you can screenshot those perfect headshots and view them in a full 360 degrees.
NVIDIA VR AUDIO Works Technology exclusive to 10 series is interative audio so realistic path traced audio meaning sound bounces off objects just like it would in the real world further improving the gaming experience on the audio side.
NVIDIA GeForce 10 series is based on 16nm finfet architecture resulting in just 180W TDP power consumption for a graphics card that can outperform Titan X in many situations whilst being upto three times more efficient. Overclocking headroom is also exceptional with around 2GHz core overclocks being possible (not guaranteed) resulting in 20% and higher overclock potential.
NVIDIA Simultaneous Multi-Projection Technology renders multi screens in one path mean performance in Virtual Reality titles on VR headsets such as HTC Vive and Oculos results in double the performance of Titan X making 10 series the King of Virtual Reality and whilst being upto three times more efficient at the same time.
Specification:
- GPU: GeForce® GTX 1080
- CUDA cores: 2560
- Video Memory: 8GB GDDR5X
- Memory Bus: 256-bit
- Engine Clock Base: TBD MHz
- Boost:TBD MHz
- Memory Clock: 10,010 MHz
- PCI Express 3.0
- Display Outputs: 3 x DisplayPort 1.4, 1x HDMI 2.0b, 1x DL-DVI
- HDCP Support: Yes
- Multi Display Capability Quad Display
- Recommended Power Supply 500W
- Power Consumption TBC W
- Power Input 2x 8-pin
- DirectX 12 API feature level 12_1
- OpenGL 4.5
- Slot Size: Large Dual Slot (2.5)
- SLI Yes
- Card Dimensions: 330mm x 152mm x 55mm
- Supported OS Windows 10 / 8 / 7 / Vista
- Warranty: 2yr
Only £619.99 inc VAT.
ORDER NOW
Specification:
- CUDA cores: 2560
- Boost:TBD MHz
- PCI Express 3.0
- HDCP Support: Yes
- OpenGL 4.5
- SLI Yes
- Warranty: 2yr
ORDER NOW
