The Phanteks Eclipse G300A boasts an impressive feature set for its compact size. You can easily build your dream gaming PC within the G300A, due to its spacious main chamber. Harness modern powerful hardware, thanks to extensive support for ATX motherboards, multiple storage drives, and even large GPUs, such as the ASUS RTX 4090 STRIX. What’s more, maintaining this powerful hardware at optimum thermal performance is simple, due to the G300A featuring outstanding cooling efficiency. There is room for multiple 120mm fans to be installed at the front, top, and rear of the case, alongside mounting points for radiators at the top and front. Additionally, your fans will have ample access to air, thanks to the high airflow mesh that Phanteks have utilised in many of the panels of the G300A
Order here:
www.overclockers.co.uk
Order here:
Order here:
Phanteks Eclipse G300A Single Fan Mid-Tower High Airflow PC Case - Black
Order Phanteks Eclipse G300A Single Fan Mid-Tower High Airflow PC Case - Black now online and benefit from fast delivery.
Order here:
Phanteks Eclipse G300A Mid-Tower High Airflow PC Case - Black
Order Phanteks Eclipse G300A Mid-Tower High Airflow PC Case - Black now online and benefit from fast delivery.
