OcUK Staff
- 1 Apr 2014
- OcUK HQ
The Meshroom S from SSUPD is a versatile Mini-ITX case, that is both easy to assemble and simple to build within. You’ll easily be able to access the interior to install any components you wish to install, thanks to the push pin panels and removable brackets. The Meshroom S offers a unique look, as the removable panels come in fossil grey, peacock blue, sage green, and charcoal black. Furthermore, the flexibility extends to cooling options, as well. With a choice of three locations for a water pump and support for two 280mm radiators, you can set up a custom water-cooling loop. Alongside this, you’ll be able to install powerful hardware. The Meshroom S is able to accommodate motherboards up to ATX size and GPUs up to 336mm long that occupy 4 expansion slots.
SSUPD Meshroom S Mini-ITX Airflow Case - Charcoal Black @ £149.99 inc VAThttps://www.overclockers.co.uk/ssupd-meshroom-s-mini-itx-airflow-case-charcoal-black-ca-00g-su.html
Mini-ITX case, Push pin assembly, Supports ATX motherboards, fully featured front I/O, supports GPUs up to 336mm, Multiple options for creating a custom loop
Only £149.99 inc VAT.
ORDER NOW
SSUPD Meshroom S Mini-ITX Airflow Case - Fossil Grey @ £149.99 inc VAThttps://www.overclockers.co.uk/ssupd-meshroom-s-mini-itx-airflow-case-fossil-grey-ca-00j-su.html
ORDER NOW
SSUPD Meshroom S Mini-ITX Airflow Case - Peacock Blue @ £149.99 inc VAThttps://www.overclockers.co.uk/ssupd-meshroom-s-mini-itx-airflow-case-peacock-blue-ca-00k-su.html
ORDER NOW
SSUPD Meshroom S Mini-ITX Airflow Case - Sage Green @ £149.99 inc VAThttps://www.overclockers.co.uk/ssupd-meshroom-s-mini-itx-airflow-case-sage-green-ca-00h-su.html
ORDER NOW
All the accessories for these cases can be found here: https://www.overclockers.co.uk/?query=Ssupd%20meshroom
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
