**AVAILABLE FOR PRE-ORDER THE JONSBO D30 AND D40 CASES**
OcUK Staff
1 Apr 2014
OcUK HQ
The Jonsbo D30 and D40 are sleek, small form factor PC cases. Their rounded edges and smooth lines give them a modern aesthetic whilst the carefully curated interior provides flexible support for your hardware. Able to accommodate up to a Micro-ATX motherboard in the D30 and ATX in the D40, you can build a powerful gaming PC within this small frame. Plus, the extensive fan and radiator support keeps the air flowing and temperatures down
Jonsbo D30 Micro-ATX PC Case - Black @ £94.99 inc VAT https://www.overclockers.co.uk/jonsbo-d30-micro-atx-pc-case-black-ca-027-jb.html
Micro-ATX PC Case, 3mm tempered glass panel, ATX PSU, Flexible storage bays, GPU up to 355mm long, Extensive cooling support
Only £94.99 inc VAT.
ORDER NOW
Jonsbo D30 Micro-ATX PC Case – White @ £94.99 inc VAT https://www.overclockers.co.uk/jonsbo-d30-micro-atx-pc-case-white-ca-028-jb.html
ORDER NOW
Jonsbo D30 Micro-ATX PC Case – Silver @ £94.99 inc VAT https://www.overclockers.co.uk/jonsbo-d30-micro-atx-pc-case-silver-ca-02a-jb.html
Micro-ATX PC Case, 3mm tempered glass panels, ATX PSU, Flexible storage bays, GPU up to 355mm long, Extensive cooling support
ORDER NOW
Jonsbo D40 ATX PC Case – Black @ £99.95 inc VAT https://www.overclockers.co.uk/jonsbo-d40-atx-pc-case-black-ca-02b-jb.html
Only £99.95 inc VAT.
ORDER NOW
Jonsbo D40 ATX PC Case – White @ £99.95 inc VAT https://www.overclockers.co.uk/jonsbo-d40-atx-pc-case-white-ca-02c-jb.html
ORDER NOW
Jonsbo D40 ATX PC Case – Silver @ £99.95 inc VAT https://www.overclockers.co.uk/jonsbo-d40-atx-pc-case-silver-ca-02d-jb.html
ORDER NOW
Really confused by the D30, it looks like an ATX case inside with the pci slots blanked off? Plus where’s the tempered glass, isn’t it all ventilated? Maybe I’m reading it wrong :)
you mean the D40... the left/tight mesh and tempered glass side panels are interchangeable. and i suspect those blanked panels are what tight cheapo company do to save money. if you want to use them you have to pop them out permanently
Aye sorry that’s the one. It comes with both glass and mesh panels? It’s just slightly weird to have the full height of an ATX case but to be configured for mATX like that. Not sure I’ve ever seen such a thing.
I may be blind but the white and black D30 look like ATX cases to my eye?
They have 7 PCIE slots and there's even the rendered mounting holes for ATX motherboards?
i think there is a complete mismatch between the images.. and the video.. the video also shows the cases complete with all riser slot brackets....
From what i can tell the pictures don't match the models. The OCUK store pages for the D30 versions are using the images for the D40 black & white (the D40's have 7 PCI expansion slot covers the D30's have 4). The silver one is using the correct images.
Also from what i can tell the OCUK store pages for the black & white versions of the D40's are using images of the VR4 black & white (the VR4's have top mounted IO and shorter top fan filter). The silver is using the correct images (front bottom right IO and full length top fan filter).
I guess @Gibbo would need to look into it after the BH.
Despite one of the pictures or anything adding up I went ahead and ordered a D30 in black. Would have liked the silver variant but not a big fan of having both panels in glass…shame Jonsbo don’t sell the panels separately.
Just got the Jonsbo D4 White Delivered, Great Service DPD/OCUK arrived today Sunday :) 10/10
There are few things you may want to know about this case on first inspection of taking it out of the box
(1) The white paint inside the front panel curves (bit of a Quality control) not fully sprayed (But ok since its don't show)
(2) The Front USB Type C in merged with the 19/20 USB 3.0 Cable (Be less half speed on External TYPE C Storage SSD)
(3) The 4 case feet very cheap & placed in the Screw Bag (This is fine by me since be adding my own Case Feet)
High Price Tag But happy with this Case, about to install the hardware :)
@rare Here you go full Build & benchmark
My Crucial X6 2TB Portable SSD - Up to 800MB/s on front Case Type C
VS
Crucial X6 2TB Portable SSD - Up to 800MB/s on a true Type C 10gb/20gb on I/O motherboard
Full speed
Nice one! Build looks superb. A bit of a shame about that USB cable mind you. Weird how they set it up that way
For £99 you would think Much better & no Cost cutting.
I Like the 2.5 SSD/HDD mounts on back & bottom, could not use the Tray at front, the drives were too thick & stopped the glass panel from slotting in.
Main reason I got this case is the Size & not taking much room on bench up.
A little bigger case I could gone for the Corsair 4000D Air flow
