OcUK Staff
Available to order today, we have the new Kolink Observatory Duo and Inspire K12. Starting with the Observatory Duo, this is the latest addition to the extremely popular Observatory range. The Observatory Duo offers both a pre-installed mesh front panel and an optional glass front panel out of the box, allowing the user to prioritise airflow or aesthetics. With 4 Kolink 120mm Umbra S ARGB/PWM fans installed as standard, along with an Umbra Core ARGB/PWM controller, both lighting effects and fan speed can be easily controlled by your motherboard software. Component support is good, with room for up to 355mm VGA cards, 160mm CPU coolers and E-ATX motherboards. Up to 360mm radiators can be installed on the front panel, and up to 280mm at the top. The I/O sports a pair of USB3.1 ports, along with a USB2 port, HD-Audio/Mic ports and buttons for both ARGB cycling and reset. The tempered glass side panel is both hinged and toolless for easy access. Overall the Observatory Duo offers quite a lot for the price and the option to swap the front panel is a nice bonus!
Moving on, we also have the Inspire K12. Joining the Inspire range, the K12 is more airflow focussed, with a mostly mesh front panel, accented by a pair of ARGB LED strips. Theres a Umbra S 120mm ARGB/PWM fan installed at the rear which is synced with the front panel ARGB, and can be controlled via motherboard software or using the LED/Reset button. The side glass panel is both hinged and magnetic, allowing easy access. Component support allows for up to ATX Motherboards, 330mm GPU's, 160mm CPU's and 180mm PSU's, along with 360mm front radiators and slim 240mm radiators on the top. Overall for the RRP this represents a solid option for a low-mid range system.
Both cases will be in stock by the weekend!
Kolink Observatory Duo ARGB Midi Tower Case - Black Window @ £69.95 inc VAT
Mid-tower case, 4 x Kolink Umbra S ARGB/PWM fans, Magnetic hinged side panel, Tinted tempered glass, Includes glass and mesh front panels, GPU support up to 355mm
Only £69.95 inc VAT.
ORDER NOW
Kolink Inspire Series K12 Midi Tower ARGB Gaming Case - Black Window @ £49.99 inc VAT
Mid-tower case, 1 x Kolink Umbra S ARGB fan, Magnetic hinged side panel, Tinted tempered glass, Two ARGB strips in front panel, GPU support up to 330mm
Only £49.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
