Stock should arrive early January for these rather tasty looking Heatkiller Blocks to fit the R290X and Titan/780Ti.
Watercool Heatkiller GPU-X ³ R9 290X @ £89.99 inc VAT
Its unique design gives extraordinary qualities to the HEATKILLER® GPU-X³. Its hallmarks are low height, state of the art cooling performance, and highest quality of material.
All water carrying parts of the cooler are made from pure electrolytic copper or stainless steel, and the connection block is made from black POM. The top is protected against staining by a special clear varnish.
Aside from the GPU, memory and voltage regulators are cooled. An extremely fine microstructure sits right above the GPU and guarantees, assisted by a low residual base thickness, optimal cooling performance. Integrated isolating stand-offs allow easy mounting of the cooler.
To reduce flow resistance and overall weight, all channels are constructed as wide as possible. Threads on both sides of the connection block ease integration into the cooling loop.
Dual- and triple-connectors for CF-setups are available.
For easy installation, pre-cut thermal pads are included.
Specifications:-
- Dimensions: 193 x 15 x 118 mm (W x H x D)
- Material: Electrolytic Copper (base), stainless steel (lid), POM (connection terminal)
- Weight: 1,000 g
- Thread: 4x G1 / 4 inch
- Pressure (tested): 5 bar
- Compatibility:
- AMD Radeon R9 290 (reference design)
- AMD Radeon R9 290X (reference design)
Only £89.99 inc VAT.
ORDER NOW
Watercool Heatkiller GPU-X ³ GTX Titan/780/780 Ti "Hole Edition" Ni-Bl @ £90.95 inc VAT
Specifications:-
- Dimensions: 188.5 x 11.5 x 118 mm (W x H x D)
- Material: Nickel plated electrolytic copper (bottom), stainless steel (lid), POM (connection terminal)
- Weight: about 900 g
Compatibility:-
- NVIDIA GeForce GTX 780 Ti (GK110, 3072 MB, reference design)
- NVIDIA GeForce GTX 780 (GK110, 3072 MB, reference design)
- NVIDIA GeForce GTX titanium (GK110, 6144 MB, reference design)
Only £90.95 inc VAT.
ORDER NOW
Watercool Heatkiller GPU-X ³ GTX Titan/780/780 Ti LT @ £75.95 inc VAT
Specifications:-
- Dimensions: 188.5 x 9.5 x 118 mm (W x H x D)
Compatibility:-
Only £75.95 inc VAT.
ORDER NOW
Watercool Heatkiller GPU-X ³ GTX Titan/780/780 Ti "Hole Edition" @ £77.99 inc VAT
Specifications:-
Compatibility:-
Only £77.99 inc VAT.
ORDER NOW
Specifications:-
- Weight: 1,000 g
- Compatibility:
ORDER NOW
Specifications:-
Compatibility:-
ORDER NOW
Specifications:-
Compatibility:-
ORDER NOW
Specifications:-
Compatibility:-
ORDER NOW
