Hi Guys
we are delighted to bring you another cool case option from Parvum Systems today.
This case is called the 'Veer' and sits between the X1.0 ITX case and the S2.0 mATX case.
This is a case that is similar in layout to the X1.0 ITX case taking many of the design features including ITX form factor and an inverted motherboard tray, but adding the additional room for a full size power supply and room in the roof for a 240mm Watercooling Radiator.
This case is a nice middle ground between the two existing cases and really stands out as being a development of end user feedback.
Parvum Systems Veer 1.0 ITX Case - White Frost @ £119.99 inc VAT
The Veer from Parvum Systems combines the stylish inverted ITX motherboard layout of their innovative X1.0 chassis design but with room to accomodate high performance watercooling solutions with ease!
Parvum have redefined small form factor builds in the past two years by evolving and being open to new ideas and designs.
The ever popular S2.0 has developed over time from customer feedback and input. Over the past two years, every modding forum on the planet has gone crazy for these small acrylic boxes and for good reason.
The latest product to come out of the Parvum think tank is the Veer1.0. This ITX chasis has been specifically designed for the water cooling enthusiast; perfect for the user that wants a small rig with more than enough cooling power to keep even the most demanding hardware at bay.
The guys at Parvum build cases how a hardware enthusiast would build a case, smart decisions are made and implemented rather than cutting corners to save costs and designs are improved and refined to offer every customer the best product on the market with a unique and personal touch.
Each Parvum case is manufactured in the United Kingdom and are built in small batches to ensure exclusivity.
As usual the Veer1.0 is crafted out of Parvum Systems now signature 5mm high quality acrylic; each case is individually cut using precise machining equipment. Each Veer1.0 is shipped flat packed.
USB3.0 headers on the front of the case compliment any modern motherboard and add to the carefully designed user experience. This discreet set of ports offer increased functionality without compromising the look of the case.
Due to Parvum constantly upgrading and updating their designs, some small aesthetic changes may occur.
Improvements in materials for case windows using scratch resistant acrylic means that your Parvum stays looking fresh whilst keeping a glass like clarity.
Most importantly, Parvum Systems takes great pride in the sourcing of their raw materials choosing a high quality, European sourced recycled acrylic. This ensures minimal waste in the production process as well as being kinder to the environment.
Specifications:
- Materials: Acrylic
- Dimensions (WxHxD): 267 x 295 x 357mm
- Maximum CPU Cooler Height: 160mm
- Motherboard Sizes: ITX
- 2.5" Drive Bays: 2
- Cooling Front: 1 x 120mm
- Cooling Rear: 1 x 80mm
- Cooling Top: 2 x 120mm
- PCI Slots: x 2
- Supports Full size power supply
- Max GPU Length: 335mm
- Max Fan/Radiator space in front of case: 100mm
- Max Fan/Radiator space in top of case: 65mm with water cooled GPU, 25mm with stock/air cooled GPU
Each case includes:
- 1x Parvum Systems F1.0 Performance Pressure Optimised Fan worth £11.99
- All required screws
Only £119.99 inc VAT.
ORDER NOW
Parvum Systems Veer 1.0 ITX Case - Blacked Out @ £119.99 inc VAT
ORDER NOW
Parvum Systems Veer 1.0 ITX Case - Black with Red @ £119.99 inc VAT
ORDER NOW
Specifications:
- PCI Slots: x 2
Each case includes:
ORDER NOW
ORDER NOW
ORDER NOW
