** AVAILABLE TO PRE ORDER - NZXT KRAKEN X31 120MM VARIABLE SPEED CONTROL AIO **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Launching today for pre order, we have the superb new cooler from NZXT.
Featuring one of the best 120mm format radiators seen on an AIO cooling unit, the X31 is the product that system builders have been crying out for.
Until now NZXT only had offerings for AIO in a 140mm form factor and multiples thereof. This limited the case choice for many users.
The new X31 offers not just a 120mm option, but an option that performs comparably to their 140mm offering as well as being quieter thanks to the new FX120 V2 Fan.
This fan has high static pressure and low noise output which makes it a perfect partner for any AIO. even the ones that come with poor stock fans ;)
All of this is controlled using NZXT CAM - an all in one control software suite that gives you control over speed and noise of the unit, not just the fan like most other AIOs, but the Pump also.
The X31 comes with a variable speed pump that operates its RPM depending on pre defined, or user set parameters.
Stock is due within the next few weeks.
NZXT KRAKEN X31 AIO Water Cooling Unit - 120mm - Variable Speed Control @ £59.99 inc VAT
The Worlds First Variable Speed Liquid Cooler
The Kraken X31 takes our Kraken platform to new depths by reimagining our industry-leading platform in a smaller, more affordable package without sacricing performance or the cutting edge technology the Kraken has come to be known for.
Improved mounting hardware and extended tubing make installing the Kraken X31 a breeze to install, while our industry leading SIX year warranty keeps your rig performing reliably at top performance. The Kraken X31’s mix of performance, affordability, and reliability makes this is the perfect time to take the plunge and "Release the Kraken!"
The Kraken X31 is one of the first consumer closed loop coolers with an integrated variable speed pump. The state-of-the-art variable speed pump keeps noise to a minimum during use without sacricing top end pump power.
In addition to the cutting edge hardware, our legacy Kraken Control software has been replaced by our all-new software suite, CAM. NZXT CAM allows you to control your Kraken X31’s fan speeds and other custom cooling settings through its Kraken+ module. CAM also supports multi-Kraken systems natively, allowing you to designate a Kraken as a CPU or GPU cooler and link the fan/pump performance to those specific components.
Specification:
- Water Block: Copper
- Pump: 2400 - 3600 ±150 RPM
- Fan Control: CAM Digital Control
Fan:
- Fan: FX120 V2
- 120 x 120 x 25mm
- Speed: 800 - 2000 PRM ± 10%
- Noise: 18 - 34 dBA
- Air Flow: 27.8 - 69.5 CFM
- Pressure: 0.44 - 2.76mmH2O
Only £59.99 inc VAT.
ORDER NOW
