Caporegime
Having problems with this adaptor on windows 11
First it didn't work so made sure was plugged in the back of the pc and I installed all Bluetooth adaptors even hidden ones, then installed the adaptors from their website and then they updated as out of date.
Worked well then had a go of Forza, but now it doesn't work again after a restart.
Oh device manager just getting "windows has stopped this device because it has reported problems"
Anyways to get this to work rather than sending back and looking for something else?
Edit**
So if I run the Bluetooth troubleshooting in windows it gets to Bluetooth state fix and says there was a problem trying to fix unresolved error however it does activate the adaptor and it works until I restart, of course it's annoying to do this every time.
But it does seem to be that windows can't change the state so wonder what workaround there is?
Edit**
