- 4 Nov 2011
- South Shields
hi just a quick question is anyone using avast 7 which was released the other day and found since installing it the performance of there systems degraded and applications took longer to open.
I installed it yesterday and found that my system was just about unusable it took me nearly 3 mins to get on to googe and 2 mins for my computer and control panel to open, if you are having issues with it i would recommend you to downgrade back to Avast 6 which works perfectly
This has been tested on 2 computers and happened on both systems
