I'm running Win7 64-bit. All security patches installed and only security patches installed.
After installing my new graphics card, I noticed that Avast antivirus wasn't loading. Strange. So I tried manually loading it and got this error message:
The application has failed to start because its side-by-side configuration is incorrect.
So I looked in the event viewer and found this further information about the error:
So I used sxstrace to get a detailed diagnosis and got a log file:
And I'm still none the wiser. I now know that side-by-side errors are a result of different versions of the same file being available and that not being handled properly and I think that in this case the problem is with a Visual C++ library, but I don't know how to fix it.
Activation context generation failed for "C:\Program Files\AVAST Software\Avast\AvastUI.exe". Dependent Assembly Avast.VC140.CRT,processorArchitecture="x86",publicKeyToken="fcc99ee6193ebbca",type="win32",version="14.0.23918.0" could not be found. Please use sxstrace.exe for detailed diagnosis.
Begin Activation Context Generation.
Input Parameter:
Flags = 0
ProcessorArchitecture = Wow32
CultureFallBacks = en-US;en
ManifestPath = C:\Program Files\AVAST Software\Avast\AvastUI.exe
AssemblyDirectory = C:\Program Files\AVAST Software\Avast\
Application Config File =
INFO: Parsing Manifest File C:\Program Files\AVAST Software\Avast\AvastUI.exe.
INFO: Manifest Definition Identity is (null).
INFO: Reference: Avast.VC140.CRT,processorArchitecture="x86",publicKeyToken="fcc99ee6193ebbca",type="win32",version="14.0.23918.0"
INFO: Reference: Avast.VC140.MFC,processorArchitecture="x86",publicKeyToken="fcc99ee6193ebbca",type="win32",version="14.0.23918.0"
INFO: Resolving reference Avast.VC140.CRT,processorArchitecture="x86",publicKeyToken="fcc99ee6193ebbca",type="win32",version="14.0.23918.0".
INFO: Resolving reference for ProcessorArchitecture WOW64.
INFO: Resolving reference for culture Neutral.
INFO: Applying Binding Policy.
INFO: No publisher policy found.
INFO: No binding policy redirect found.
INFO: Begin assembly probing.
INFO: Did not find the assembly in WinSxS.
INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_32\Avast.VC140.CRT\14.0.23918.0__fcc99ee6193ebbca\Avast.VC140.CRT.DLL.
INFO: Did not find manifest for culture Neutral.
INFO: End assembly probing.
INFO: Resolving reference for ProcessorArchitecture x86.
INFO: Find publisher policy at C:\Windows\WinSxS\manifests\x86_policy.14.0.avast.vc140.crt_fcc99ee6193ebbca_14.0.24210.0_none_914751ebea0c5702.manifest
INFO: Publisher Policy redirected assembly version.
INFO: Post policy assembly identity is Avast.VC140.CRT,processorArchitecture="x86",publicKeyToken="fcc99ee6193ebbca",type="win32",version="14.0.24210.0".
INFO: Attempt to probe manifest at C:\Windows\WinSxS\manifests\x86_avast.vc140.crt_fcc99ee6193ebbca_14.0.24210.0_none_9e58d6f8311e6fc8.manifest.
INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_32\Avast.VC140.CRT\14.0.24210.0__fcc99ee6193ebbca\Avast.VC140.CRT.DLL.
INFO: Attempt to probe manifest at C:\Program Files\AVAST Software\Avast\Avast.VC140.CRT.DLL.
INFO: Attempt to probe manifest at C:\Program Files\AVAST Software\Avast\Avast.VC140.CRT.MANIFEST.
INFO: Attempt to probe manifest at C:\Program Files\AVAST Software\Avast\Avast.VC140.CRT\Avast.VC140.CRT.DLL.
INFO: Attempt to probe manifest at C:\Program Files\AVAST Software\Avast\Avast.VC140.CRT\Avast.VC140.CRT.MANIFEST.
ERROR: Cannot resolve reference Avast.VC140.CRT,processorArchitecture="x86",publicKeyToken="fcc99ee6193ebbca",type="win32",version="14.0.23918.0".
ERROR: Activation Context generation failed.
End Activation Context Generation.
Input Parameter:
Flags = 0
ProcessorArchitecture = AMD64
ManifestPath = C:\Windows\system32\ndfapi.dll
AssemblyDirectory = C:\Windows\system32\
INFO: Parsing Manifest File C:\Windows\system32\ndfapi.dll.
INFO: Manifest Definition Identity is ndfapi,processorArchitecture="amd64",type="win32",version="1.0.0.0".
INFO: Reference: Microsoft.Windows.Common-Controls,language="*",processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0"
INFO: Resolving reference Microsoft.Windows.Common-Controls,language="*",processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0".
INFO: Resolving reference for ProcessorArchitecture amd64.
INFO: Resolving reference for culture en-US.
INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_64\Microsoft.Windows.Common-Controls\6.0.0.0_en-US_6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en-US\Microsoft.Windows.Common-Controls.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en-US\Microsoft.Windows.Common-Controls.MANIFEST.
INFO: Attempt to probe manifest at C:\Windows\system32\en-US\Microsoft.Windows.Common-Controls\Microsoft.Windows.Common-Controls.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en-US\Microsoft.Windows.Common-Controls\Microsoft.Windows.Common-Controls.MANIFEST.
INFO: Did not find manifest for culture en-US.
INFO: Resolving reference for culture en.
INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_64\Microsoft.Windows.Common-Controls\6.0.0.0_en_6595b64144ccf1df\Microsoft.Windows.Common-Controls.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en\Microsoft.Windows.Common-Controls.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en\Microsoft.Windows.Common-Controls.MANIFEST.
INFO: Attempt to probe manifest at C:\Windows\system32\en\Microsoft.Windows.Common-Controls\Microsoft.Windows.Common-Controls.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en\Microsoft.Windows.Common-Controls\Microsoft.Windows.Common-Controls.MANIFEST.
INFO: Did not find manifest for culture en.
INFO: Auto Servicing Policy redirected assembly version.
INFO: Post policy assembly identity is Microsoft.Windows.Common-Controls,processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.7601.18837".
INFO: Attempt to probe manifest at C:\Windows\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757.manifest.
INFO: Manifest found at C:\Windows\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757.manifest.
INFO: Resolving reference Microsoft.Windows.Common-Controls.mui,language="*",processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.7601.18837".
INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_64\Microsoft.Windows.Common-Controls.mui\6.0.7601.18837_en-US_6595b64144ccf1df\Microsoft.Windows.Common-Controls.mui.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en-US\Microsoft.Windows.Common-Controls.mui.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en-US\Microsoft.Windows.Common-Controls.mui.MANIFEST.
INFO: Attempt to probe manifest at C:\Windows\system32\en-US\Microsoft.Windows.Common-Controls.mui\Microsoft.Windows.Common-Controls.mui.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en-US\Microsoft.Windows.Common-Controls.mui\Microsoft.Windows.Common-Controls.mui.MANIFEST.
INFO: Attempt to probe manifest at C:\Windows\assembly\GAC_64\Microsoft.Windows.Common-Controls.mui\6.0.7601.18837_en_6595b64144ccf1df\Microsoft.Windows.Common-Controls.mui.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en\Microsoft.Windows.Common-Controls.mui.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en\Microsoft.Windows.Common-Controls.mui.MANIFEST.
INFO: Attempt to probe manifest at C:\Windows\system32\en\Microsoft.Windows.Common-Controls.mui\Microsoft.Windows.Common-Controls.mui.DLL.
INFO: Attempt to probe manifest at C:\Windows\system32\en\Microsoft.Windows.Common-Controls.mui\Microsoft.Windows.Common-Controls.mui.MANIFEST.
INFO: Parsing Manifest File C:\Windows\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757.manifest.
INFO: Manifest Definition Identity is Microsoft.Windows.Common-Controls,processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.7601.18837".
INFO: Reference: Microsoft.Windows.Common-Controls.Resources,language="*",processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0"
INFO: Resolving reference Microsoft.Windows.Common-Controls.Resources,language="*",processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.0.0".
INFO: Post policy assembly identity is Microsoft.Windows.Common-Controls.Resources,language="en-US",processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.7600.16385".
INFO: Attempt to probe manifest at C:\Windows\WinSxS\manifests\amd64_microsoft.windows.c..-controls.resources_6595b64144ccf1df_6.0.7600.16385_en-us_106f9be843a9b4e3.manifest.
INFO: Manifest found at C:\Windows\WinSxS\manifests\amd64_microsoft.windows.c..-controls.resources_6595b64144ccf1df_6.0.7600.16385_en-us_106f9be843a9b4e3.manifest.
INFO: Parsing Manifest File C:\Windows\WinSxS\manifests\amd64_microsoft.windows.c..-controls.resources_6595b64144ccf1df_6.0.7600.16385_en-us_106f9be843a9b4e3.manifest.
INFO: Manifest Definition Identity is Microsoft.Windows.Common-Controls.Resources,language="en-us",processorArchitecture="amd64",publicKeyToken="6595b64144ccf1df",type="win32",version="6.0.7600.16385".
INFO: Activation Context generation succeeded.
Input Parameter:
Flags = 0
Input Parameter:
Flags = 0
