Avast + Sandybride
13 Dec 2003
UK
Has anyone with a Sandybridge setup use Avast Antivirus
every time I seem to install Avast Free Home Edition, when my system is starting up it kind of hangs at the desktop with the cursor going in a circle
I don't know if its a compatibility thing or a software conflict
Btw system is fully stable & rock solid, were taking 12hrs prime etc...
every time I uninstall it, the system is fine
I have reformatted about 3 times now
lastly have used the system for 2 days perfectly then installed Avast, rebooted and bang! ... and the dirt is gone .... erm I mean same problem as before
I dont think its a software conflict, just this new Avast not playing ball
(I've also tried my system at stock with the same issues)
.... very strange
I'm not fobbing you off mate, but you'd be better off asking at the Avast Forum. Not only will there be more specific experience there, but the devs actually post there so they can actually solve the issue at software level if needed. :)
