** AVEXIR LED DDR4 2400-3600MHz NOW AVAILABLE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
This is so new, most of it is not even on Avexir website yet, OcUK is worldwide first with this memory and as such were offering special PRE-ORDER ONLY LOW pricing, you will notice most of this very special LED PULSE memory is cheaper than most other brands which feature no LEDs due to our special promotional pricing which last until stock lands, approx. 2 weeks.
We have Skylake and Haswell-E kits, there are many so I shall only show a few examples so be sure to check out the memory section on our website to see all the kits we have available as our range of dual channel DDR4 is the largest in Europe on gaming modules. :)
Avexir Core Red Series 8GB (2x4GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit (AVD4UZ124001604G-2CIR) - Red Light @ £49.99 inc VAT
Avexir Core series is a simple yet elegant low profile premium design which incorporates an LED tube which gives the LED a gentle pulsing effect, giving your system not only an awesome look but also a very unique look as Avexir has patents making it the only memory to use this gentle pulsing yet very impressive visual technology. Avexir is ONLY available from Overclockers UK and Caseking in Europe.
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Core Series is designed to be a perfect visual match for Asus ROG, EVGA, Asrock Fatality, Gigabyte and MSI Gaming mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black high performance heatspreaders
- LED Strobe lighting effect
- CAS Timings: 16-16-16-36
- Dual Channel Kit: (2x4GB)
- 100% tested at 2400MHz in Intel Z170 Skylake based motherboards
- Lifetime Warranty with OcUK
Only £49.99 inc VAT.
ORDER NOW
Avexir Core Blue Series 16GB (2x8GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit (AVD4UZ124001608G-2CI) - Blue Light @ £89.99 inc VAT
Features:
- Black PCB
- Dual Channel Kit: (2x8GB)
Only £89.99 inc VAT.
ORDER NOW
Avexir Core White Series 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (AVD4UZ124001608G-4CIW) - White Light @ £149.99 inc VAT
Features:
- Black PCB
- Quad Channel Kit: (4x8GB)
- 100% tested at 2400MHz in Intel X99 Haswell-E based motherboards
Only £149.99 inc VAT.
ORDER NOW
Full Range of DDR4 2400MHz Memory Kits
Avexir Core Red Series 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (AVD4U26661504G-4CIR) - Red Light @ £119.99 inc VAT
Features:
- Black PCB
- CAS Timings: 15-15-15-35
- Quad Channel Kit: (4x4GB)
- 100% tested at 2666MHz in Intel X99 Haswell-E based motherboards
Only £119.99 inc VAT.
ORDER NOW
Avexir Core Red Series 32GB (4x8GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (AVD4U26661508G-4CIR) - Red Light @ £215.99 inc VAT
Features:
- Black PCB
Only £215.99 inc VAT.
ORDER NOW
Full Range of DDR4 2666MHz Memory Kits
Avexir Blitz Original Red 8GB (2x4GB) DDR4 PC4-24000C15 3000MHz Dual Channel Memory Kit - Red Light (AVD4UZ130001504G-2BZ1RR) @ £74.99 inc VAT
Avexir Blitz Original series is a design which is loud and shouts high performance and incorporates an LED tube which gives the LED a gentle pulsing effect, giving your system not only an awesome look but also a very unique look as Avexir has patents making it the only memory to use this gentle pulsing yet very impressive visual technology. Avexir is ONLY available from Overclockers UK and Caseking in Europe. Blitz Original series also features hand selected IC for higher clock speeds and/or tighter latency timings making them more ideal for those wishing to overclock or tighten latencies on their memory kit.
Avexir Blitz Original Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Blitz Original Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Blitz Original Series is designed to be a perfect visual match for Asus ROG, EVGA, Asrock Fatality, Gigabyte and MSI Gaming mainboards, giving you a look which shall make you the envy of all your friends.
Features:
- Black PCB
- Voltage: 1.35v
- 100% tested at 3000MHz in Intel Z170 Skylake based motherboards
Only £74.99 inc VAT.
ORDER NOW
Avexir Blitz Original Silver 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Memory Kit - White Light (AVD4UZ130001508G-2BZ1SW) @ £139.99 inc VAT
Features:
- Black PCB
- Voltage: 1.35v
Only £139.99 inc VAT.
ORDER NOW
Avexir Blitz Original Red 32GB (4x8GB) DDR4 PC4-24000C15 3000MHz Quad Channel Memory Kit - Red Light (AVD4UZ130001508G-4BZ1RR) @ £259.99 inc VAT
Features:
- Black PCB
- Voltage: 1.35v
- 100% tested at 3000MHz in Intel X99 Haswell-E based motherboards
Only £259.99 inc VAT.
ORDER NOW
Full Range of DDR4 3000MHz Memory Kits
Avexir Blitz Original Red 8GB (2x4GB) DDR4 PC4-28800C18 3600MHz Dual Channel Memory Kit - Red Light (AVD4UZ136001804G-2BZ1RR) @ £79.99 inc VAT
Features:
- Black PCB
- CAS Timings: 18-20-20-40
- Voltage: 1.35v
- 100% tested at 3600MHz in Intel Z170 Skylake based motherboards
Only £79.99 inc VAT.
ORDER NOW
Avexir Blitz Original Silver 16GB (2x8GB) DDR4 PC4-28800C18 3600MHz Dual Channel Memory Kit - White Light (AVD4UZ136001808G-2BZ1SW) @ £149.99 inc VAT
Features:
- Black PCB
- Voltage: 1.35v
ORDER NOW
Avexir Blitz Original Red 32GB (4x8GB) DDR4 PC4-28800C18 3600MHz Quad Channel Memory Kit - Red Light (AVD4UZ136001808G-4BZ1RR) @ £289.99 inc VAT
Features:
- Black PCB
- Voltage: 1.35v
- 100% tested at 3600MHz in Intel X99 Haswell-E based motherboards
Only £289.99 inc VAT.
ORDER NOW
Full Range of DDR4 3400MHz and above Memory Kits
As you can see truly great looking memory, incredibly low prices and OcUK truly is King of DDR4 memory. :)
OcUK Full Memory Range - Click Here!
And the price barrier between DDR3 and DDR4 really starts to disappear...
Really might be time to start thinking about a new pc again ... :)
I apologise for my ignorance, I know very little about DDR 4 yet, but these rated speeds actual speeds or is it like DDR 3 where basically using 2400 memory was always "Outside of the recommended chipset specification"?
intel say there cpu's can do 2133mhz, so anything above is a bonus. tbh with skylake i think most if not all chips can do over 3000mhz easy.
Hello Gibbo.
Avexir has said that there DDR4 Raiden series memory has been released for a while now. Why hasn't OCUK not carried it yet????
The price is to high. So we have for now decided not to carry them.
Maybe in the future or when the Red versions become available we shall carry them. :)
Really there that expensive? I was really looking forward to them, but if there too much then maybe it's a good reason you don't carry them. Cheers for this info :)
