20 Feb 2008 at 11:16 #1 Mikoyan Mikoyan Soldato Joined 4 Aug 2004 Posts 2,734 Location on OCUK Can anyone tell me how to tell AVG that a file that AVG thinks is a virus.....isnt..kind of like putting an .exe in a safezone?? Thanks
20 Feb 2008 at 11:27 #2 bledd bledd Don Joined 21 Oct 2002 Posts 46,844 Location Parts Unknown avg is crap use avast instead
20 Feb 2008 at 11:48 #3 Mikoyan Mikoyan Soldato OP Joined 4 Aug 2004 Posts 2,734 Location on OCUK I know but a customer uses it at thier site !
20 Feb 2008 at 11:49 #4 bledd bledd Don Joined 21 Oct 2002 Posts 46,844 Location Parts Unknown tell them to get nod32 if they want to pay for av -btw i don't know, you probably can ignore it
20 Feb 2008 at 12:01 #5 FuhhQ FuhhQ Permabanned Joined 2 Feb 2008 Posts 28 if its a run once file e/g a setup file the simply disable avg until installation is complete
20 Feb 2008 at 14:16 #6 LoadsaMoney LoadsaMoney Caporegime Joined 8 Jul 2003 Posts 30,063 Location In a house All you can do is disable AVG so you can use said file, until an update cures the problem.
20 Feb 2008 at 15:08 #7 Mikoyan Mikoyan Soldato OP Joined 4 Aug 2004 Posts 2,734 Location on OCUK thanks for the input and meh to avg
