avi audio question
17 Jul 2009
at home, you?
i have an avi file i want to burn to a dvd, but the audio is pants, i wish to edit the audio settings before i burn to make it sound better, what software is best for this? and if you can suggest me one, with instructions on how to do so (i.e web link) this would be a lot better, so ocuk, have at it
If you're just trying to change the bass/treble or something like that then you'll need to extract the audio stream, edit it and then add it back in.
Using Virtual Dub + Audacity (Free) will do the job or Sony Vegas (Not free) which could do a more fancy job.
