Some files dont play.
I've got 100's of Avis and they all play, one is playing now, this one,
Format : AVI
Format/Info : Audio Video Interleave
File size : 700 MiB
Duration : 1h 25mn
Overall bit rate : 1 147 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Writing library : VirtualDubMod build 2366/release
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 1h 25mn
Bit rate : 945 Kbps
Width : 572 pixels
Height : 312 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.221
Stream size : 577 MiB (82%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
but when I used Alive HD video converter to convert a .M2TS file, I used the Avi option and the converted Avi doesnt play, here is the info on it.
General
CompleteName : C:\New Folder\00001.avi
Format : AVI
Format_Profile : OpenDML
FileSize/String : 2.99 GiB
Duration/String : 4h 52mn
OverallBitRate/String : 1 467 Kbps
Movie : 00001
Encoded_Application : Lavf52.22.1
Video
Format : S-Mpeg 4 v2
CodecID : MP42
CodecID/Info : Microsoft MPEG-4 V2
BitRate/String : 1 406 Kbps
Width/String : 720 pixels
Height/String : 480 pixels
DisplayAspectRatio/String : 1.500
FrameRate/String : 29.970 fps
Standard : NTSC
Resolution/String : 24 bits
Bits-(Pixel*Frame) : 0.136
StreamSize/String : 2.87 GiB (96%)
thanks in advance
I'll add confusion these three were done using Ulead/ Aone, my DivX player rejects them aswel.
1.
Complete name
Format : AVI
File size : 1.73 GiB
Duration : 2h 8mn
Overall bit rate : 1 935 Kbps
Writing library : MPlayer
Video
Format profile : Simple@L1
Format settings, BVOP : No
Codec ID : DX50
Duration : 2h 8mn
Bit rate : 1 763 Kbps
Width : 1 280 pixels
Height : 720 pixels
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.080
Stream size : 1.58 GiB (91%)
Writing library : Lavc51.44.0
2.
Format : AVI
Format profile : OpenDML
File size : 4.24 GiB
Duration : 5h 33mn
Overall bit rate : 1 824 Kbps
Movie name : 00001
Writing application : Lavf52.16.0
Video
Format profile : Simple@L3
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 5h 33mn
Bit rate : 1 771 Kbps
Height : 720 pixels
Colorimetry : 4:2:0
Stream size : 4.12 GiB (97%)
Writing library : XviD 1.1.2 (UTC 2006-11-01)
3,
Format : AVI
File size : 3.08 GiB
Duration : 5h 33mn
Overall bit rate : 1 321 Kbps
Movie name : 00001
Writing application : Lavf51.17.0
Video
Codec ID : DIVX
Codec ID/Info : Project Mayo
Codec ID/Hint : DivX 4
Duration : 5h 33mn
Bit rate : 1 268 Kbps
Height : 720 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.057
Stream size : 2.95 GiB (96%)
Writing library : Lavc51.47.0
Format : AVI
File size : 700 MiB
Duration : 1h 25mn
Video
Codec ID : DX50
Duration : 1h 25mn
Bit rate : 945 Kbps
Width : 572 pixels
Height : 312 pixels
Colorimetry : 4:2:0
General
Format : AVI
Movie : 00001
Video
CodecID : MP42
Standard : NTSC
thanks in advance
1.
Complete name
Format : AVI
Duration : 2h 8mn
Video
Codec ID : DX50
Duration : 2h 8mn
Height : 720 pixels
Colorimetry : 4:2:0
2.
Format : AVI
Duration : 5h 33mn
Movie name : 00001
Video
Codec ID : XVID
Duration : 5h 33mn
Height : 720 pixels
Colorimetry : 4:2:0
3,
Format : AVI
Duration : 5h 33mn
Movie name : 00001
Video
Codec ID : DIVX
Duration : 5h 33mn
Height : 720 pixels
Colorimetry : 4:2:0
