Avi to DVD
20 Jan 2004
Bristol
Hi
Ive got some .AVI video that I want to burn to dvd using Nero. As I understand it I need to convert these to Vob files, if so what free software should I use.
Thanks
As above, best piece of video conversion software I have ever used, so easy to use and very good results.
Nero can encode them to DVD format without any need for other software; just select 'make own dvd-video' and drag over files want making into a dvd.
Thanks for that i will give it a try.
I will also give Nero an other go but I thought it would not recognise the files last time I tried, is it any version of Nero?
Nero 6 does not have the 'Make DVD-Video' option but Nero 7 Premium which I use does have the option and have made DVD's from AVI's using Nero many times.
