AVI TO DVD
18 Oct 2009
Edinburgh, Scotland
Whats the fastest program out there that will convert my avi files to dvd? also whats the best program to burn the dvd files with?
I dont wanna use nero as a lot of junk comes with it and this is just a fresh install
thanks
convertxtodvd is the best i can convert a film from avi to dvd in 5-8 mins if you want it shoot me a email and i will send it you. Best burning program is Ashampoo burning studio
DVDFlick is fast and free, converts a full movie to DVD in 30~ minutes. It also has IMGburn built in so if you choose to burn after encode completes it will manage all that.
convertxtodvd is the best ive dealt with it converts it then burns it straight to dvd all in about 6-8 mins and also very easy to use
