I have the Abit AW9D-MAX running the Intel Core Duo X6800 Chip with the GeIL 2GB (2x1GB) PC6400C4 800MHz RAM in it.
Now using the SPD setting etc (basically not touching BIOS and letting it boot up) its running a 1.8v and 5-5-5-15.
Now according to the sticker on the chip it says it can run at 2.1v and does 4-4-4-12. Thing is when i did this it was giving Errors in Memtest 1.70.
So i took it back to OC's and said its failing at the speeds it should do, so since i couldn't go without RAM i brought some more to replace it (of the same type of RAM). Tried the same and the new RAM threw up errors at the above timings.
So i left it at the SPD settings etc and picked up the RMA'd RAM i took back to find its not faulty and runs perfectly... which slightly annoyed me, guy in the shop said i should try 2.2v's which hasn't worked.
So currently i've tried the following
1.8 at 5-5-5-15 (works)
1.8 at 4-4-4-12 (errors)
2.0 at 4-4-4-12 (errors)
2.05 at 4-4-4-12 (errors)
2.1 at 4-4-4-12 (errors)
2.2 at 4-4-4-12 (erros)
I'm not great with messing in BIOS but if anyone has the same M/board CPU and RAM and knows how to set this up incase i'm missing out a step i should be doing would be a great help
Thanks in advanced
