- 27 Dec 2005
- Bristol
This doesn't really fit neatly into another forum (video maybe?? software maybe??) so hopefully I'll get a quick answer and it'll drop off the bottom.
I'm putting together a presentation for an awards ceremony on Friday that'll be part of a charity ball. I run a video agency so I'm all good on the tech front but I'm probably overthinking it for the visuals.
Ideally I want a presentation type setup that goes through each award - award title, nominees, then winner - preferably a bit smoother than just a fade and where each slide constantly loops some kind of awards animation so there's time for whoever's on the mic to waffle.
There'll be a 15s snippet of a song for the winners to walk up to etc and if that can be embedded/automated into the presentation rather than being a separate/manual process then all the better.
I've got a decent After Effects awards template for the visuals but the transitions between slides won't be dynamic obviously. It's actually been a while since I've use Powerpoint but maybe that can do the job in terms of looping background video and embedded music?
Any ideas/recommendations?
