Awesome Design? Look no further than the new Xigmatek case.
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
I have something a little bit different now. A cube case, and a good price. This chassis also offers full watercooling support, I can imagine it now, with a front bay res and a 240mm radiator and some lovely mayhems pastel fluid. A GTX 580 or a ATi 7970 GPU all powered by a 2700K overclocked and cool :) Stock is due in the next week or so.
Xigmatek Gigas Micro ATX Cube Case - Black @ £89.99 inc VAT
Balance meets awesome design, functionality and size. Small outer dimensions but huge capability of housing high end hardware is one of the main advantage of our new HYBRID Chassis “GIGAS”. Supporting 2*5.25” ODD, 6*3.5” HDD and 2*2.5” SSD, and total length of 320mm or 12.5” graphic cards. Optimized airflow system by four preinstalled 1000 RPM fans and standard 120mm heat-pipe side blow CPU cooler. Start the GAME with GIGAS!!!
- Full aluminum Micro-ATX chassis for gaming and HTPC.
- Available for 12cm side-blow heatpipe cooler within 160mm height.
- Dual 330mm high-end long graphic cards available.
- Six 3.5" HDD space with anti-vibration rubbers.
- Two 2.5" SSD/HDD available.
- Two external 5.25" bays for optical drive and HTPC control panel.
- Two preinstalled 12cm 800RPM front black fans and two 12cm rear fan space for optional.
- One USB3.0 front port available.
- Dimensions: 278(W) x 322(D) x 396(H) mm
- Drive Bays: 5.25” External x 2
- Drive Bays: 3.5” Internal HDD x 6 on two HDD cages (with anti-vibration rubbers)
- Drive Bays: 2.5” Internal HDD x 2 on two HDD cages
- Expansion Slot: 4 slots (Available graphic card length: 320mm)
- Motherboard Support: Micro ATX, ITX
- Front Cooling: Pre-installed 120mm black fans x 2 (1000RPM)
- Rear Cooling Fan: Pre-installed 120mm black fans x 2 (1000RPM)
- Max CPU cooler height: 160mm
- Water-cooling: 120mm All-In-One water-cooling device available
- I/O Panel: Power button, Reset button, USB3.0 x 1(internal 20pin), USB2.0 x 2, HD Audio in/out x 1
Only £89.99 inc VAT.
ORDER NOW
I think that look fantastic! Perfect for a compat W/C build. Price is good also.
That description impies it comes with an integral cpu cooler but I am asuming that it will simply fit any cpu cooler up to a certain size...? :confused:
Tempted...
/Salsa
nice, ive been saying for a while that you could do with some more decent SFF cases that can take full sized PSUs, and you've definitely delivered with this one :)
Well our range is just going to get better and better, mark my words. We will be the king of cases!
Any Reviews?
Any more pics?
some of the older Lian Li stuff looked pretty damn good in red and blue, any mroe colours of this to come?
What kind of air coolers are going to fit in here?
There looks like there's a bit of a flaw in this 'water-cooling' case. the position of the PSU just above the PCIe slots means that you can't install any GPUs with tall heatsinks - i.e. no gpu water-cooling.
May be wrong as the pictures aren't too clear.
looks like your right about the PSU placement, but i'd be very surprised if xigmatec didnt think about that when putting the case together. i expect they will fit, but it will be tight
