** AWESOME GAINWARD PHANTOM GRAPHICS CARD DEALS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some awesome deals on Gainward cards guys and remember the advanced warranty and support Gainward give exclusively to OcUK:-
Gainward GeForce GTX 780 Phantom GLH 3072MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 980 MHz
- Core Boost Clock: 1033 MHz
- Memory Clock: 6200 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£539.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 780 Phantom 3072MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
Features:-
Specification:-
- Core Base Clock: 902 MHz
- Core Boost Clock: 954 MHz
- Memory Clock: 6008 MHz
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£499.99] Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 770 Phantom 4096MB GDDR5 PCI-Express Graphics Card @ £335.99 inc VAT
Gainward GTX 680 Phantom, continue the elegant design of the first generation. The new Phantom III comes with brand new fins design (patent pending) that introduces 1) better thermal performance 2) lower acoustic level 3) more solid structure than previous generation. With this new outstanding innovated thermal design and optimized product design Gainward GTX 770 Phantom delivers an extreme gaming performance for enthusiast gamers.
Gainward Grand-Prix Heat-Pipes Hybrid Cooler, was designed in 8mm copper-water heat-pipes on a copper base conducting heats away from GPU at highest efficiency, then dissipating onto aluminum heatsinks, which are forced ventilated with Great 8 cm silent PWM fans (GR8) which are also removable.
Great 8 cm silent PWM Fan (GR8) achieves highest cooling performance at much lower temperatures under power saving mode.
Specification:-
- Core Clock: 1046MHz (GK104)
- Core Boost Clock: 1085MHz
- Memory: 4096MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2300MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£359.99] Inc. VAT
Only £335.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 770 Phantom 2048MB GDDR5 PCI-Express Graphics Card @ £305.99 inc VAT
Specification:-
- Core Clock: 1150MHz (GK104)
- Core Boost Clock: 1202MHz
- Memory: 2048MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£319.99] Inc. VAT
Only £305.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 770 2048MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Shader Clock: 2170MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£305.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 760 Phantom 2048MB GDDR5 PCI-Express Graphics Card @ £191.99 inc VAT
GeForce® GTX 760 is the new weapon of choice for gamers—a powerful graphics card that gives you fast, smooth, quiet performance in all your favorite titles. It’s packed with next-gen technology innovations, engineering, and features that let you crank up the settings and resolutions in graphics-intensive games like Splinter Cell: Blacklist.
Take hyper-realistic gameplay to a whole new level with NVIDIA GPU Boost 2.0 for max clock speeds, PhysX® and TXAA™ for great graphics, and NVIDIA® SHIELD™ compatibility for incredible portable gaming. Plus, instantly access the latest game-ready drivers automatically—the day a game launches—and optimize settings with one click using GeForce Experience™. Even auto-record all your greatest gaming moments with NVIDIA ShadowPlay.
This is serious equipment for the serious gamer.
Features:-
- Ultra Durable VGA Design
- WindForce 3x Cooler - Quieter, Cooler, better fans with Triangle Cool Technology
- GPU Boost 2.0
- Support up to 4 displays at single car and maximum 4k resolutions
- Direct Heat Pipe touch technology (DHT)
Specification:-
- Core Clock: 1072MHz (GK104)
- Core Boost Clock: 1137MHz
- Memory Clock: 6200MHz (Effective)
- Processing Cores: 1152
- Shader Clock: 2144MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£199.99] Inc. VAT
Only £191.99 inc VAT.
ORDER NOW
Gainward GeForce GT640 2048MB GDDR3 PCI-Express Graphics Card @ £59.99 inc VAT
The Gainward GT 640 2GB supports all of the latest features of New GeForce 600 series, including Adaptive Vsync for smoother game play, PhysX, DirectX 11, and Blu-Ray 3D support. The GT 640 is also the first mainstream GeForce graphics card capable of driving up to 3 displays for surround gaming and general use, making multi-display more accessible and affordable than ever. The most common display types are supported right out of the box, including HDMI, DVI, and VGA.
- 384 Cuda Cores
- 900MHz Core Clock
- 1782MHz Shader Clock
- 2048MB GDDR3 Memory
- 1800MHz Memory Speed
- 128-Bit Memory Interface
- Connectivity: 1x Analogue, 1x HDMI & 1 HDMI
- Cool, Quiet, Fast and Affordable
- Better Videos, Photos, Web, and Games
- Greater Productivity
- SMX power efficiency
- Quad display support
- 9 x over integrated
- TDP 65W
- 2yr Warranty
Was [£65.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Gainward really supporting OcUK well as can be seen with these great prices and remember these are mostly Phantom prices at incredible prices. :)
Does the glh version provide anything over the non-glh version other than a slightly higher oc?
Any chance these will be cheaper in the next few months after the 290x is released?
Oh and how do they compare to the MSI lightning and evga supercharged models?
Glh is the new golden sample version, chips are binned afaik, so possibly worth the extra £20.
Classy and lightning still lead the way but the glh isn't far behind, it also has memory over voltage too which not many cards outside of the usual elite have :)
Very happy with mine, very quick and quiet.
Used to run a pair of Gainward 260s which gave excellent service for a few years. However the 2 year warranty on these cards always make me hesitant when looking to buy one.
Put my Gainward branded GTX 690's through their paces for months and ran faultless. Went with EVGA this time though for the longer warranty and piece of mind of a quick turn around.
It is not the quality of the warranty that I have an issue with, I'm sure OCUK will handle that to their usual high standards.
Other manufactures however do offer 3 year warranties with their cards, and for me that is an important factor when choosing a graphics card.
