Noob questions.
Hi,
Just looking at both of these products and their 'free' tiers for tinkering around and experimenting.
It appears they like to confuse things with their always free, 12 months free options, Azure more so. Does the free tier end after the 12 months is up or can it still be used for free if you're only using the always free products?
But, for instance, if I wanted a light weight database on AWS, probably a few thousand rows at the most, would that always be free? It looks like it would be.
I take it that it would be possible to knock up a AWS dbase and then create software that connects to that instead of a local dbase?
thanks
EDIT: I suppose the Google Cloud Platform should sit within this query too.
Hi,
thanks
