AX1200 PSU in a HAF 932 advice needed
29 Aug 2010
Cornwall
Hi all,
Quick question, I'm about to fit a AX1200 PSU into a HAF 932 case.
I'm planning on fitting it in the bottom of the case.
Which way up should the PSU be?
There is a slight platform underneath the PSU to raise it up to the level of the hole in the back. now there are gaps in this platform but I'm wondering if it will obstruct airflow into the PSU which has a top/bottom mounted fan.
How well does it work if you mount a PSU in the bottom of the case with the fan at the top? Is there any affect on performance?
Can it damage the PSU if it is operated the wrong way up?
Cheers all.
