OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Available to pre-order now and landing in our warehouse imminently the Shine 6 is here!
This version will have ABS keycaps but each keyboard has a letter to send with details of how to claim your PBT keycaps once they are finished (there was a problem during production).
Only available in brown switch version for now. As and when the other switch types become available I'll list them on the website (no current info on when this will be).
Ducky Channel Shine 6 Mechanical RGB Gaming Keyboard, Brown Cherry MX Switch, UK Layout @ £159.95 inc VAT https://www.overclockers.co.uk/duck...own-cherry-mx-switch-uk-layout-kb-21u-dk.html
Colourful RGB Backlighting, SIDE RGB Lighting, Brown Cherry MX Switch, Included Mouse Bungee
Features
A variety of colorful RGB backlighting
100% Full Backlighting, Breathing, Color Cycling, Wave and Rain Drop mode. Allow users to adjust RGB backlighting color and decrease/ increase speed.
Side LED lighting
RGB LED on each side of the keyboard, and also provide many modes including Smart, 100% Full backlight, Marquee and Color Cycling
Operational flexibility Mouse bungee
Can install on right or left side and adjust the direction.
Removable Rubber feet
A solid feeling pair of rubber feet are installed for the user who prefer higher angles on their keyboard
The best Made in Germany Cherry MX RGB switches
Ducky uses only genuine Cherry MX switches, and its life cycle for over 50 million times. Standard cross-shaped, allow users to replace keycaps easily.
Dual-layer PCB
This will give longer life expectancy as well as signal stability of the keyboard functions.
More brightness SMD RGB LED
3528 SMD RGB LED and in back soldering technology to improve the backlight brightness.
USB N-Key Rollover
Under USB, the Ducky Shine 6 Special Edition can handle any number of simultaneous key presses. You can use the keyboard confidently in any situations knowing that there will never be ghosting or key blocking issue. Also can switch to 6-Key Rollover mode.
Specification
Model: DKSH1608ST
Type: Mechanical Keyboard
Switch: Brown Cherry MX RGB switches
LED: RGB color LED
Keycap material: PBT or ABS
Legend printing: Double-Shot or Laser Engraved
Dimensions:450 x 155 x 45 mm
Weight:1.1kg
Origin of Production:Taiwan
Only £159.95 inc VAT.
ORDER NOW
Features
Side LED lighting
Dual-layer PCB
USB N-Key Rollover
Specification
Model: DKSH1608ST
LED: RGB color LED
Weight:1.1kg
ORDER NOW
