**AYE AYE CAPTAIN: MAKE IT SO!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Sorry about the title for this thread, but got two new Calibre cards from Sparkle which are well called Captains. :D
Sparkle Calibre GeForce GTX 680 Captain 2048MB GDDR5 PCI-Express Graphics Card @ £419.99 inc VAT
The Captain Series is the flagship product line of the Calibre designed by Sparkle range of products.
Calibre X680 & X670 Captain Series is built for enthusiasts ready to tackle hungry gamers’ demands. By utilizing a Cool Pro Cooling System, Triple Silent PWN Fans with specialized Compact Stack Fin Heat Sinks which optimizes air flow through 6mm six ultra cool heat pipes providing strong thermal-hydraulic cooling performance. Furthermore, 6+2 Phases power design provides stability at load, while 2oz Copper PCB delivers better energy efficiency and stability for overclocking. Moreover, with an all solid state components design the Calibre X680/X670 Captain Series delivers the extremely gaming experience like never before.
The Captain Series is the flagship product line of the Calibre designed by Sparkle range of products. Calibre products are aimed at consumers who demand above reference performance with bespoke design, factory overclocking with custom cooling systems the Calibre X680/ X670 Captain Series is preloaded with overclocking value for enthusiasts.
Features:-
- Trio Silent PWM Fans: With trio fans which provides best airflow, easily takes away the heat from the compact stack cooling fins.
- 6pcs Ultra Cool Heat Pipes: 6pcs ultra cool heat pipes provide strong thermal capacity to deliver ultimate cooling performance.
- 6+2 Phases power design.
- 2oz Copper PCB.
- 300W Capable design: Ideal for maximum OC potential.
- Upto 4 monitor support out the box.
Specification:-
- Core Clock: 1124MHz (GK104)
- Core Boost Clock: 1189MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6200MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2248MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Only £419.99 inc VAT.
ORDER NOW
Sparkle Calibre GeForce GTX 670 Captain 2048MB GDDR5 PCI-Express Graphics Card @ £329.99 inc VAT
Features:-
- 2oz Copper PCB.
Specification:-
- Core Clock: 954MHz (GK104)
- Core Boost Clock: 1033MHz
- Processing Cores: 1344
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 1x 8-Piin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Only £329.99 inc VAT.
ORDER NOW
These Captains are certainly quick out the box, but even better pretty much near damn silent, a pair of nice cards indeed.
WARP SPEED! :D :D :D
Purchased a Sparkle card from OC back in the Nvidia GTX275 days, never again, it failed and I had to contact Sparkle for help, I strongly recommend you avoid Sparkle at all costs, the European distributor even started throwing insults and accused me of trying to blackmail them.
Each to their own, I will not turn this into a flame Sparkle thread though.
A lot of money to put out on a little known brand. Been trying to find a reasonably priced 670 all day to compare with a 7950 but failed miserably, the only one being the Pov that Ocuk have been trying to punt but I dont know anything about Pov so dont want to take a chance on it. These cards look good, like the Phantom, but with the Gigabyte 7950 so cheap and the 12.11 driver improvements its really a no contest, hell I even found a Gigabyte Windforce 7970 cheaper than 670, Nvidia need to get competitive as I have no preference with brand, just value for performance.:)
Sparkle has been around for awhile - usually used for OEM, etc. cards but done the odd retail line. No idea what their customer service is like as none of the ones I've used have ever had a problem (built several machines with their GTX260s for people) but I suspect you can deal with it through OcUK rather than Sparkle for the first 1-2 years should it come to it.
If i rememer correctly, sparkle is more of an american brand?
The cooler reminds me of the phantom series coolers.
