- 7 Sep 2020
Just build a new Gaming pc and as im working from home felt that it was finally time.
components
Asus ROG Strix Z490-F Gaming (Socket LGA 1200)
Intel Core i5-10600K 4.10GHz (Comet Lake) Socket LGA1200
16GB (2x8GB) DDR4 PC4-28800C14 3600MHz Dual Channel Kit
Noctua NH-D15 Chromax Pure Black CPU Cooler
I have 1GB internet connection from Virgin media speed tests consistently give me around 940 ish down
Using the above new components i noticed my speed tests had dropped dramatically, firstly thinking it was an issue with my internet then virgin tested the line and speeds to the router I done the thing i should have tried in the first instance - Another pc
So having another pc and laptop i connected up to the same cable and hey presto my speeds were back to normal.
back to the z490 board and it was struggling.
I have tried various drivers updated the firmware re-installed and nothing will make the on-board lan run even close to its advertised speeds.
So to fully convince myself I went and purchased the cheapest pcie 1gb network card i could find and give it a try- The results were full speed and exactly what i should expect.
So I contacted OC whom i have found to be absolutely outstanding when it come to any issues.
They replaced the z490 board which I have just received only to have the same issues and poor speeds with the on-board Intel® I225-V 2.5Gb Ethernet
I found another forum which a long list of others experiencing the same problem.
really disappointed in this board
components
