B Grade GPU bargains !!
2 Jan 2012
UK.
How have they suddenly got 10+ stock off all these b grade cards? Are these ones that have possibly been sitting in the warehouse and boxes have been damaged? Seems strange to have 10+ of each card returned.
Something wrong with how each page is set up I'm guessing?
When you type B-grade into the search and click on watercooling, you will find items which you cant see if you go directly to watercooling>clearance watercooling :confused:
The 780 Lightning does look tempting, but just bagged myself a 780Ti IChill X3 for £210 in the MM :D
And a b-grade waterblock for £30 using the above method :D
Can remember buying a single lightning for £400 in June.
However I'll say they perform no better than any other 780 and the cooler isn't even that great.
