hi guys i just bought a gtx 980 strix from ocuk from the clearance section got it for a good price and it looks like new but im less than happy with the temps i am getting from it.
at idle its at 46c now i know the fans turn off but this does seem quite high on load something strange is going on, the card on full load using heaven benchmark with no overclock runs at 75c/76c @61% fan speed which is acceptable if not a little loud! with overclock but no volt increase the temps go to 81c @ 68% fan speed its starting to get quite loud, at this temp the boost clock is dropping 24mhz, now the strange thing is if i manually set the fan speed from 68% to 100% the temps only drop by 2c it seems to make no difference what speed the fans are running at soon as you go over 60% and that's with my case closed or open.
gpu temp on idle- voltage @ 0.862 fan speed manual at 100% 35c whats up with this card?
