how would that work tho as pretty much all the B Grade items are missing bit of packagingMeatLoaf said:i would imagine its 14 days with ocuk and then you should get some form of manufacturers warranty.
Servo said:If you check the Graphic's card section, you will notice it gives the direct telephone number for rma replacement.
i bought a mobo from a competitors b grade and it is still going strong today, it was an Asus P4C800 Delux for £40m3csl2004 said:erm im pretty shure it depends what item you buy, ie, dfis boards are bare board rma so there warrenty still counts but i know some manufacturers arnt like that
tbh i would buy stuff like cpus/graphics as if they work within the first few days then they generally wont fail, but motherboards and hard drives and stuff sometimes do fail in normal operation, hence it would be nice to have a good solid warrenty
dale1uk said:I've had a reply regarding warranty on b-grade products. Basicly you only get the 14 days from OCUK, after that you're on your own - NO manufactures warranty![]()
