B grade items
29 Dec 2008
what do u get with B grade items?
im guessing they were used in display instore or returned items but what im worried about is if they have things missing (i.e missing power mains, cd's, sata cables etc) and if they come with warranty.
if there could be missing bits is it possible to call ocuk and ask what is missing on specific items?
bgrades can have missing bits like sata cables backplates etc, warranty length will depend upon each individual item and 14 days with OCUK
i bought a b-grade motherboard and it came in it's box with everything included as per the manufacturers website. Has worked flawlessly. The only thing i can think of that made it bgrade was there being no cellophane on the box.
Guess it's the luck of the draw and all that though.
Expect a bare motherboard in a brown cardboard box and anything else you get will be a bonus. They are still generally decent buys though. Most motherboard manufacturers will supply spare I/O shields for a few pounds and they all honour the warranty directly.
Do be aware though that a some of it doesn't work out of the box and you either have to send it back or RMA it to the manufacturer.
I've always found it's not worth the hassle just to save a few quid.
Get the item brand new with full guarantee.
I've always had good luck with B grade so far, my HDD, GFX and DVD-RW are all B Grade and all work perfectly.
In some sence, you know OC have tested it to make sure it works before selling it. But there is still always the chance it died in transit
It varies from item to item. If you are interested in a particular item, I suggest that you give the shop a call.
few days ago, i saw some Abit IP35-Pro XE MBs in bgrade for £45, new ones are £95, thats £50 off and thats more then enough to cover the cost of any cables and backplates that might be missing. so personally i say at times it is worth the hassle if the savings are significant enough, although say that there are times when new is cheaper then b-grade
This may be true if it is just a couple of quid, as said above though sometimes real bargains can be had.
I got my 9800gtx+ for £92 when they were £150 new. Was fully boxed complete aswell :)
Had a B-grade hard drive aswell (which is basically OEM) for about £20 less than retail.
My IX38 came with nothing yesterday, bar its 14 day warranty. That makes it a little better than buying off the auction site... and tbh, the price wouldnt have been better 2nd hand anyway.
There was still a little bit of heat paste round the cpu socket, and even on a capacitor where the previous owner wasnt careful. One of the sata socket surrounds was snapped. Doesnt really give me confidence that the last owner treated it right before rma'ing it.
Seems to be working ok so far, but havent done extensive testing yet.
:( i really hope that my motherboard comes with all the bits and bobs and that it ofcourse works fine. id love ocuk foreverandeverandever! :p
I also have a b-grade IX38; bought it in August, has been working perfectly since :) Nothing came with mine either though.
I bought a 'B' grade MSI board, Worked fine for a month then died on me. NOT O/C FAULT. Fair enough, just waiting for my replacement now.
Would definitely buy again.
Cheap as chips:D
Just bought one myself, it came as the bare board with nothing else, I haven't had a chance to test it out fully yet but at the moment I'm saving £50 and I've already got spare SATA and IDE cables as well as front and rear USB/firewire connectors that I can use.
I bought a b grade dark power.
It was obvious it had been opened, but was still really tidy and to be honest brilliant. I wasnt expecting it to even come boxed, its now running like a rock and I saved 30 quid.!
As we say a t work a WIN WIN!
