B Grade Laptops
31 Oct 2011
N Ireland
Whats the risk in buying the b grade laptops what's the possible reasons why they would be b grade? Can you return of you feel it's not in acceptable condition or working order?
Thinking of getting this saving £100 on discounted new price. My budget is £1000.
https://www.overclockers.co.uk/b-gr...-intel-i7-7700hq-gaming-laptop-bg-56e-ms.html
Any use for Battlefield V Arma etc?
Thanks for your help and advice
If it's not fit for use it won't be sold as B grade I'm sure everything has to be functional, I'm sure you'd not get a laptop that is buggered I can't imagine it'll be much different to a new one aside from opened packaging and a few scuffs here and there. I've use a laptop with a GTX1060 before and it played everything I threw at it, cities, Assassins Creed Origins, GTA V, all maxed.
Most of the time b grade laptops are usually just opened boxes as they have been returned as unwanted. You are in your right still to return the item within 14 days if you change your mind also. So the 14 days gives you a bit of time to check the condition.
I bought a gaming laptop from OcUK as a 'B' grade. Absolutely fine. I got a cracking deal on a laptop that had had the box opened.
Went an ordered it so fingers crossed. OcUK haven't let me down yet :) Hopefully get me some Haribo aswell lol. Thanks all.
if new is only £100 more i would pay that simply because you get extra year warranty 2 years new vs 90 days B grade, which with laptops is well worth it in my opinion.
Got a little more off it after speaking to some of the OcUK guys earlier and getting the price amended. I had a max budget of £1000; the discount i eventually received made me feel abit more comfortable and of course it was a little easier to persuade the wife lol
