hey guys,
looking at getting a 1440p monitor, just seen the DGM in the B-Grade section for £300.
are these worth getting? have they got bad image quality etc?
just abit cautious about a B-Grade monitor
cheers
According to the piles of posts I've read on here the DGM monitors power brick is notorious for going boom, Personally I'd spend the extra on the version that comes with a full warranty.
hmmm... looks like the hazro is next in line then :/
I've got 3 DGM's, had them over a year, good picture quality, the only issue with them is the stand is a bit naff, but it's a minor concern considering the price
so no issues with the power brick? b-grade DGM's worth getting?
my opinion on b-grade monitors are as follows
As a Primary monitor on your main system - AVOID AT ALL COST due to possibility of issues from dead pixels to warranty
As a monitor on a secondary system, where you just need something cheap to show an image, I would consider b-grade provided new is not around a similar price or cheaper
okey dokey non b-grade it is, anyone using the hazro monitor me and dicehunter are looking at?
this one
http://www.overclockers.co.uk/showproduct.php?prodid=MO-012-HO&groupid=17&catid=1120
