B-Grade Phanteks P600s
17 Mar 2011
Snowdonia
Im interested in the Phanteks P600s and ocuk has B-Grade models available.
https://www.overclockers.co.uk/-b-g...s-silent-midi-tower-case-black-bg-05m-pt.html
I'm not a fan of tempered glass side panels and fancy rgb so this looks a decent case option for me.
I enquired about what to expect from a B-grade case regarding condition or missing accessories etc but they could not give specifics.
£50 is a decent saving but not sure its worth the risk of having ugly scratches and dents on it. How are their b-grade cases generally?
Anyone here use this case by the way? Feedback on the case would be good.
I bought a b grade Phanteks 719 which appeared to be just open box, but when removed could see the glass door had slipped out of its shipping bracket and dropped, bending the hinges quite badly. otherwise it was mint with all accesories unopened, so rather than return it i flattened the hinges out which was pretty easy and ended up with a basically new case for about 40% less.
Got few B-Grade cases before. Only once the case wasn’t as new. It was the Phanteks Enthoo Primo. The dual fan side bracket was missing. Apart from that, all perfect.
All other cars even came with the plastic film on the glass.
P600S is my all time favourite case, Phanteks take great pride in their work and it really shows! Bgrade with OCuk has always been spot on for me, you can also message customer services with a cheeky offer and they usually accept or come back with a number they can accept. OCuk customer service is also second to none!
B grade usually means something is missing or box is opened for whatever reason. Only had a couple of items where it hasn’t been spot on otherwise they are usually like new.
The two items I had issues with were a PSU missing some pcie cables and an AIO which had been previously installed with cross threaded screws. Neither of which gave me much hassle.
I got a couple of cases from B stock they were all new condition with all the bits in it
Love my white P600s and I wouldn't change it for anything out there. If you haven't already, buy it.
It really is a superb case.
I have the gunmetal version, absolute dream to build in, with great cable management and loads of space for SSD/HDD"s.
Probably the last case I will ever buy, unless something drastic happens.
