Zotac Z-Box SD-ID12 Intel Atom Mini PC
Take the first step to living green with the eco-friendly and energy-efficient ZOTAC ZBOX SD-ID12 mini-PC powered by Intel® Atom™ technology combined with Intel® Graphics Media Accelerator 3150 graphics. The ZOTAC ZBOX SD-ID12 mini-PC delivers phenomenal performance and compatibility for a full Microsoft® Windows® 7 experience with Aero® user interface while maintaining best-in-class energy-efficiency. The ZOTAC ZBOX SD-ID12 mini-PC is easy to master with only two thumb screws in place to unlock the internal expansion capabilities. Inside the ZOTAC ZBOX SD-ID12 mini-PC is space for a 2.5-inch SATA hard drive and 204-pin DDR3 DIMM module while USB 2.0, eSATA and a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) provide external expansion.
Specifications
• Intel® Atom™ D525 CPU (1.8 GHz, dual-core)
• Intel® NM10 Express chipset
• Intel® Graphics Media Accelerator 3150 GPU
Inside the box
• ZOTAC ZBOX SD-ID12
• Power brick & cable
• VESA monitor mount (w/4 screws)
• Stand
WWW.ZOTAC.COM
SKU: ZBOXSD-ID12
Internal Expansion
• 1 2.5-inch SATA 3.0 Gb/s hard drive
• 2 204-pin DDR3-800 SO-DIMM
Display Outputs
• HDMI (720p)
• HDCP compliant
• VGA
Front Ports
• Headphone/Audio out jack
• Microphone jack
• 6-in-1 Memory card reader
• (MMC/SD/SDHC/MS/MS Pro/xD)
• 1 USB 2.0 port
• WiFi LED
• Hard drive LED
• Power button
Features
• Intel® HyperThreading technology
• Intel® ClearVideo (SD) technology
• Microsoft® DirectX® 9 compatible
• OpenGL® 1.5 compatible
• Energy-efficient computing
Dimensions
• Length: 7.40in - 188mm
• Width: 7.40in - 188mm
• Depth: 1.73in - 44mm
Rear Ports
• eSATA
• 4 USB 2.0 ports
• 10/100/1000 Ethernet (RJ45)
• Digital S/PDIF output
• Power connector
Top Ports
• 1 USB 2.0 port
With the SSD bundle Option
Zotac Z-Box SD-ID12 + Samsung SpinPoint M8 160GB 5400RPM SATA-II 8MB Cache - OEM (HN-M160MBB) @ (£135.00ex vat per unit)
Zotac Z-Box SD-ID12 + SanDisk Ultra SSD 60GB 2.5" SATA-2 Solid State Hard Drive - (SDSSDH-060G-G25) @ (£141.40ex vat per unit)
Zotac Z-Box SD-ID12 + Samsung SpinPoint M7 320GB 5400RPM SATA-II 8MB Cache - OEM (HM321HI) @ (£146.00ex vat per unit)
Zotac Z-Box SD-ID12 + SanDisk Ultra SSD 120GB 2.5" SATA II Solid State Hard Drive - (SDSSDH-120G-G25) @ (£160.47ex vat per unit)
These deals are only available to trade, Contact details found below.
These system are great for entry level use i.e (all office apps,facebook & movie playback) Great space saver can almost fit these units anywhere. Also will fit to the back of VESA screens saving you even more desk space.
Contact Details
Private Trade
MSN - [email protected]
Skype - PmjFraser
Email - [email protected]
Phone - 0871 200 5058
Public Sector / Education
Skype - Adrian_austin1
Specifications
Inside the box
• Stand
WWW.ZOTAC.COM
SKU: ZBOXSD-ID12
Internal Expansion
Display Outputs
• HDMI (720p)
• HDCP compliant
• VGA
Front Ports
• Microphone jack
• 1 USB 2.0 port
• WiFi LED
• Hard drive LED
• Power button
Features
Dimensions
Rear Ports
• eSATA
• 4 USB 2.0 ports
• Power connector
Top Ports
• 1 USB 2.0 port
Contact Details
Private Trade
Skype - PmjFraser
